Lemay
- South Florida
- EC
Recently, during a review cycle in Miami Beach for a Service Replacement, the Authority Having Jurisdiction (AHJ) required the owner to sign a Hold Harmless Agreement because the Group Metering Equipment was rated NEMA 3R instead of NEMA 4X. The AHJ referenced a Memorandum that broadly classifies all coastal areas as corrosive environments. Based on the research I’ve gathered, this interpretation appears to be an overreach of the applicable standards.
Next week, I’ll be presenting this case at the BORA hearing for clarification.
From my review of multiple regulatory standards, corrosive is consistently defined as a reaction involving living tissue, not environmental conditions or exposure to salt air. Furthermore, the Group Metering Equipment we are installing is not manufactured in NEMA 4X due to its "Hosedown" rating, which makes sense—nobody would take a garden hose to unfused electrical equipment.
I’m seeking input or advice from anyone with relevant experience or insights that could strengthen my case. Here are the references that highlight how corrosive agents and environments are defined in various standards:
References:
- OSHA – Corrosive Agents (29 CFR 1910.1200):
A corrosive agent is defined as a chemical that causes visible destruction or irreversible changes to living tissue at the point of contact. - Florida Building Code (FBC) – [F] CORROSIVE:
A chemical that causes visible destruction of or irreversible alterations in living tissue by chemical action at the point of contact. A chemical shall be considered corrosive if, when tested on the intact skin of albino rabbits per DOTn 49 CFR, Part 173.137, it irreversibly alters tissue within 4 hours. This definition explicitly excludes action on inanimate surfaces. - U.S. Department of Transportation (49 CFR 173.137):
Corrosive locations are defined by the chemical impact on living tissue, not general environmental conditions. - National Electrical Code (NEC 2020, Article 680.2):
Defines corrosive environments specifically in swimming pool areas and chemical storage locations where chemicals are stored, handled, or dispensed.
