p51 said:
I just finished a job for a customer (restaraunt owner/gen. contractor).We installed wiring for a existing 45kw generator on roof of restaraunt,Including a 400 amp 3/0 transfer switch on roof with wiring for existing 400 amp service. I agreed to do this on a T&M basis with a 20% mark up on material @ the customers insistence which was below my usual mark up of 40-50%,I dont usually do T&M but times are slow so I agreed. Today I gave the cust. the bill for materialx1.20 and labor @ normal rate of $85 hr. for a lic. journeyman and $45 hr for a exp. helper (my cost $30 & 15 hr.). The contractor insists the 20% markup should include labor @ cost "plus" 20% my cut of this would be a whopping $9 dollars an hr. Has anyone ever run across this type of situation? I would like to get some feedback if possible before I reply to my customer Thanks
well, it's TIME and MATERIAL, not COST and MATERIAL.
your whole reason to be there is to sell skilled labor, and provide material
for the skilled labor to install, and to make a living doing that. you have
an hourly shop rate, right? not an hourly shop cost.....
what part did you have in writing? i've done this stuff on verbal, and
regretted it. sounds like you have a bs artist just trying to chisel you.
nobody does what he's asking you to do. not me, and if you are smart,
not you.
i did some work for a machine tool broker years ago... when i presented
the bill, he chiseled me to knock 10% off the total bill. i was new, and
got suckered. after he'd written me the check, then he told me what he
had sold my labor for, with a grin, rubbing it in.
i did work for him for two more years, and EVERY bill i submitted to him
had a "correction factor" applied. it was the amount i had discounted
the first bill, applied to every single bill thereafter.
i have seen PPE for electricians, never for a doormat. if you use PPE,
you aren't a doormat.
randy
