B747Man
- California
- Unemployed
Hello, so please forgive if this question is not allowed or belongs in another forum. Anyway, I live in an older house that was built in the 1950s and even though I have the three-hole outlets, my surge protector shows 2 of them as being ungrounded. The thing is I want to be able to run a portable AC on that outlet and want to make sure it's safe. I am having an electrician come to some other work and was hoping it might not cost that much more to make the outlet grounded while they are here. It's a small house and the outlet would be on the same wall as the panel which is at most around 10 feet away. There is an attic as well as a crawlspace underneath the house.
Do you have a general estimate of what it might cost to at least run new wires that have ground to that outlet? As far as I know the the current wiring is early Romex or early NM without the ground which means the other outlets probably aren't grounded either. If it helps I live in Southern California.
Also, would the price be that much different if they put the outlet on its own circuit since they would need to run new wires anyway? That way it will be the only thing running on the circuit.
Thanks
Thanks
