Gosh.. LEDs are still extremely complicated to use correctly. It seems like magnetic transformer is the only way you can dim 12v LEDs and stay compliant with radio frequency emissions requirements.
For the original poster: You would use a transformer like this one. I think this is like a regular low voltage MAGNETIC transformer with a rectifier output. You then use a AC power line side dimmer intended for MLV
https://www.pegasuslighting.com/12-...onstant-voltage-led-driver-nora-lighting.html
The pass through dimmer you put on the output side chops the DC into small bits and feeds it into field installed LED rope which can turn into interference emission antenna. If the frequency is high enough to avoid visible flicker, it may make noise you can hear or cause harmful radio interference.
Another method is solid state dimmable LED driver/transformer for 12v LED which is PWM method. It's best to not use this method unless it's a commercial property due to high levels of radio interference generated.
Gar, "
8. If you have separate low voltage dimmers on the output side of the power supply, then individual strips of LEDs can be separately dimmed from one power supply."
It would appear you need a linear regulator. The cheap ones online do not have a substantial heat sink and I believe they're RF spewing type. It doesn't look like enforced code regulates wiring done on Class 2 side even if it causes harmful interference. So, it's a partial regulatory vacuum. RFI emitting LEDs are still the wild west just like drone laws.
Lutron's official page says:
NOTE: This equipment has been tested and found
to comply with the limits for a
Class A digital device,
pursuant to part 15 of the FCC Rules. These limits
are designed to provide reasonable protection
against harmful interference when the equipment is
operated in a commercial environment. This
equipment generates, uses, and can radiate radio
frequency energy and, if not installed and used in
accordance with the instruction manual, may cause
harmful interference to radio communications.
Operation of this equipment in a residential area is
likely to cause harmful interference in which case the
user will be required to correct the interference at his
own expense.
This device complies with part 15 of the FCC Rules.
Operation is subject to the following two conditions:
(1) This device may not cause harmful interference,
and (2) this device must accept any interference
received, including interference that may cause
undesired operation.
