cburke1111
- Fort Myers
- EC Electrician
Does anyone have any experience installing LED sheets beneath a countertop? I would greatly appreciate any insights or recommendations you could share.
Below, I have outlined the products that the customer intends to use.
Evo-Lite | Advanced Luminous Solutions
TUNABLE WHITE
666b0a5b0279b74d123fc6f3_AG2-TW Spec Sheet_2324i.pdf
RGB + WHITE (5000K)
658ed651005946f4a67b1b80_AG2-RGBW Spec Sheet_3823i.pdf
Questions
TUNABLE WHITE
RGB + WHITE (5000K)
Questions
- It would be great if you could send pictures of the installation process.
- How much spacing did you use between the LED sheets and the countertop?
- What did you do about cutting holes in the LED sheet for the sink, outlets, and other stuff?
- I plan on installing plywood first and then the LED sheets on top of the plywood. Did you do something?
- This product recommends setting bumpers between the LED sheets and the countertop. Did you use these, or did you find something better?
