sparky1967
- Seattle, WA, USA
I really hope this hasn't been covered multiple times here because I'm getting crosseyed reading everything I can find about the SABC two circuit requirement and haven't found this specific question discussed:
210.52 (B) (3) - Receptacles installed in a kitchen to serve countertop surfaces shall be supplied by not fewer than two small-appliance branch circuits....
If I read that literally, it means that each receptacle has to have two (or more..??) circuits feeding it. So, quite literally, you'd bring both SABC circuits into the box, break the tab between the two halves of the duplex receptacle, wire one circuit to the top half and the other circuit to the bottom half. Really? Is that really what the code is saying?
OR -
Is it saying that you need to have at least two receptacles (which could be duplex), each one fed by a different SABC?
On a related note: Do you guys type out the section of code you're talking about each time you make a reference to it? I haven't been able to find an online source to the code book that can be copied and pasted but I'm seeing a lot of posts here with code text that looks like it's been pasted or quoted from somewhere.
Thanks for helping a noob out!
OR -
