jeepx
- knoxville,tn,united states
Maybe im confused but if you have a twenty amp single phase two wire circuit and check the amperage on the neutral at the panel you should read almost zero on a neutral sharing three circuits you will read the imbalance between the three phases so with that said if you have a@5amps b@5amps c@7amps then the neutral should read the difference of roughly 2 amps and should be considered a CCC where as in reality the neutral of a single circuit really carries no amps it is all being used up at what ever the circuit is powering up engineering and diagrams look good on paper as well as theory so am I wrong
