i have a little project that needs to be finished this weekend & i have a couple of question that i can't find the answer for in the nec
i need to run 3 300' straight runs of 1 1/4" pvc conduit , in 2'- 3' ditch all 3 will 90 up at both ends & will not be securely mounted on either end,with a pull string in each, question should i or would you install expansion joints in this situation? once its covered i don't think the temperature will change that much ( pacific northwest)
also HO has a 60 amp temp power pole installed by transformer now he wants power to his temperary well shed about 50' from transformer ( after the house is built the shed will be move to another location) the shed will also house a computer & security cameras so he can monitor the contactors from his home 100 miles away. question can i feed a 30 amp sub panel to the outside of the shed from the temp power, 4 wire uf buried 2' deep all exposed wiring in conduit, also if i can will i need a main breaker at the sub panel or can i use main lug panel. there will be 1-2pole breaker & 1 or 2 single pole breakers in sub panel.
thanks for your input
