Cover over ground connections.
slo7682
How do you answer someone's question of 'why is there not a cover over open ground connections such as at a ground bar or at a ground rod or a small ground wire tapped to a larger ground wire?'
give them the basic non-electrician answer: "If we covered that, we'd have to cover the earth because it's theoretically all the same voltage potential."
