We have several areas in our facility where the use of mobil cranes is required to perform maintenance/construction. According to NFPA 70E Sect. 130.8 if working around "Uninsulated Overhead Lines" than the following guidelines should be followed. However, we have several aerial cables that are "insulated". How does 70E apply to these? What are requirements if energized? Also, does this differ from what OSHA requirements state? Do OSHA standards suppercide 70E?
