crazy bout tap conductors
linwue
Minnesota
tap conductor? What would the tap cond. size be if I were feeding a 100 amp panel from a 600 amp disconnect,distance is less than 25ft.
Any help?
Re: crazy bout tap conductors
Read 240.21.B2 and try to work out an answer.
Come back with the answer an we will help you determine the conductor size if you are incorrect.
I come up with a 3/0.I took 1/3 of 600amps which is 200amps which I believe would be a 3/0
