cwdick
- Paducah, Ky. USA
I am currently working on a project that has 4 points in the systems where we have electrical hardware.
We are using an aluminum triplex drop cable ran overhead, 480Vac Single Phase
We start at point 4 and this is the location of our 480Vac single phase source
The span from point 4 to point 3 is 2000 feet. The triplex will branch off at point 3 to a 480/120 transformer. The load at point 3 is 630 Watts
The span from point 3 to point 2 is 500 feet. The triplex will branch off at point 2 to a 480/120 transformer. The load at point 2 is 1890 Watts
The span from point 2 to point 1 is 2000 feet. The triplex will end at point 1 and will terminate at a 480/120 transformer. The load at point 1 is 330 Watts
My question is the voltage drop at each point if using a cable made by Houston Wire with specs of the following:
Aluminum Triplex Service Drop Cable
Cable Code Name: Voluta
Phase Conductor Size: 6
Phase Conductor Stranding: 7
Phase Conductor Covering Thickness: 45
Bare Neutral Messenger Size: 6
Bare Neutral Messenger Stranding: 6/1
Bare Neutral Messenger Rated Strength (lbs.): 1190
Weight per 1000 feet: 116 lbs
Ampacity: 70 amps
Thank You
Ampacity: 70 amps
Thank You
