gar
- Ann Arbor, Michigan
- EE
141109-2932 EST
Today at Home Depot a Cree soft white LED 60W was just under $5 and with tax just over $5. I believe this is subsidized by DTE.
Bought one for test in my range top hood. Should not be a problem because there is good air flow even with the fan off, and bulb axis is horizontal. However, when the range is in use the ambient is higher, and there may be a lot of moisture at times,
I have previously had failure of a 9.5 W Cree (60 W equivalent) in a more mild environment.
