CREE T8 drop-in LED safety recall. requires immedaite stop of use
Electric-Light
A recall was announced on June 4th, 2015 on select CREE T8 drop-in LED lamps.
Affected device should be removed from service immediately. You can elect to receive a refund or a replacement.
Announced on http://www.cpsc.gov/en/Recalls/2015/Cree-Recalls-LED-Lamps/
Affected are are T8 drop-in tube replacement LED lamps below.
BT848-17027FLW-BDG13-1C100 Linear LED T8 Replacement, Lamp, 4 Ft, 1700 Lm, 2700K - US 849665002932
BT848-17040FLW-BDG13-1C100 Linear LED T8 Replacement, Lamp, 4 Ft, 1700 Lm, 4000K - US 849665002154
COMMERCIAL Product Number Description
LEDT8P-48-21L-35K Linear LED T8 Replacement, Lamp, 4 Ft, 2100 Lm, 3500K
LEDT8P-48-21L-40K Linear LED T8 Replacement, Lamp, 4 Ft, 2100 Lm, 4000K
LEDT8P-48-17L-35K Linear LED T8 Replacement, Lamp, 4 Ft, 1700 Lm, 3500K
LEDT8P-48-17L-40K Linear LED T8 Replacement, Lamp, 4 Ft, 1700 Lm, 4000K
LEDT8P-48-17L-30K Linear LED T8 Replacement, Lamp, 4 Ft, 1700 Lm, 3000K
LEDT8P-48-17L-50K Linear LED T8 Replacement, Lamp, 4 Ft, 1700 Lm, 5000K
LEDT8P-48-21L-30K Linear LED T8 Replacement, Lamp, 4 Ft, 2100 Lm, 3000K
Date Codes: Any of the above product numbers with any of the following date codes are affected: 3314, 3414, 3514, 3614, 3714, 3814, 3914, 4014, 4114, 4214, 4314, 4414, 4514, 4614, 4714, 4814, 4914, 5014, 5114, 5214, 0115, 0215, 0315, 0415, 0515, 0615, 0715, 0815, 0915, 1015, 1115, 1215, 1315, 1415, 1515, 1615
You can expect to receive your refund approximately 2-3 weeks after Cree receives your Cree? LED T8 Replacement Lamps. To begin the process, please contact Cree Customer Service either via phone at (888) 338-7883, or via email at T8LED@cree.com
You can expect to receive your replacement LED T8 lamp approximately 3-4 weeks after Cree receives your Cree? LED T8 Replacement Lamps, beginning July 1, 2015. To begin the process, please make contact with Cree Customer Service either via phone at (888) 338-7883, or via email at T8LED@cree.com
