oilheadbob
New member
- Virginia
Okay,
I understand that the CSST gas pipe must not be bonded. Here is my problem. The gas meter is on one side of the house I am working on. The water lines in the house are PVC. The electrical panel and ground electrodes are on the opposite end of the house. It just doesn't make sense to me to run the bond accross the house 60+ ft to get to the panel or ground electrodes to bond the CSST where it enters the residence.
This is a result of having the gas furnace replaced. The house was built in 2002 prior to the new code requirements.
Can you drive two new ground electrodes and bond there?
Thanks,
Bob Ryan
Gaineville, Va.
Thanks,
Bob Ryan
Gaineville, Va.
