CT cabinet bonding
chris kennedy
Miami Fla.
60 yr old tool twisting electrician
Quite a while ago someone posted fitting/lug that could be used to bond the grounded conductors to the cabinet without cutting the conductors.
I bookmarked it but it must have been on the old computer. Anyone remember what that was?
celtic said:
Was this a fitting to combat choke?
No sir, picture a PVC conduit install between CT cab and main disco. I run EGC's back to the CT can.
It was a pretty slick deal for bonding the can.
I thought I knew what you were talking about on the first post now I am clueless.
This is what I thought you were looking for but I think this is not what you want.
If I have 3 sets of 600's passing through the can, I would like to bond the can without bringing 3/0 EGC from the main back to the CT can.
that my friend is a Lay-In lug
Why not use a NSI block there about $55.00. thats what I use on My CT cabinets. I'll see if I can find a pic
I always used a "stud kerney". Its basically a split bolt with a stud made onto the head so you can bolt it thru your cabinet and lay your grounded conductor in.
A little off topic:
Why does the neutral bus in a CT can have plastic insulators under it?
I question this everytime I run a bonding jumper from it to the CT can, if I could just remove those insulators(legally) and bolt that bus right to the can I would not need the jumper.
Cow said:
A little off topic:
I'm sorry, we use doughnut pass through CT's here.
Around here the neutral gets bonded directly to the can. There is no EGC on the line side of the service disconnect.
