First, if a line to case fault were to occur in a CT cabinet and the CT enclosure did become energized how do you know when the fuses in the transformer will open? It seems that the potential for a 3?x 3? energized metal enclosure could be a real danger. I once heard that the galvanized mast of a service began to glow due to unopened fuses in the transformer (story less than confirmed though).
Second, this CT cabinet is mounted to a stanchion 10? away from the utility pole 100? away from the main disconnect mounted on the residence. Is there any need to ground this cabinet to ground rods for lightning path and if so, should they be connected to the utility ground rod which is driven a couple feet from the stanchion.
Thanks for any help.
