timm333
- Minneapolis, MN
- Electrical Design Engineer
I have a question about the sizing of the cable on CT secondary. Which IEC standard gives the criteria to calculate the wire size on the secondary of CT?
For example if the CT ratio is 400:1, CT rated burden is 10 VA, the distance from the CT to relay is 100 m, relay burden is 0.1 VA: then will a 4 mm2 cable be enough to connect the CT secondary to the relay? Thanks.
