sparkyjpb
- S/E Michigan
I don't do much commercial and this job I'm quoting will only be the the 2nd with a CT cabinet. Here's the facts-school maintenance garage, upgrading the service from single phase 200 amp to single phase 400 amp, 1 meter on building, 3- 500's in 3" riser out of top of ct, gutter under ct, under gutter 2 disconnects 1-100 amp and 1-200 amp, pipe out to respective sub panels. What is the process of grounding? From each disconnect to ground rods? What about the water pipes bonding? Trying to expand a little, just need some help.
Thanks Guys
Thanks Guys
