CT Shorting Blocks Permanent vs Removable Screws
yesterlectric
Texas
I install what's specified on my jobs and sometimes it's what comes with the equipment. However, when dealing with single ratio CT's on a 3 phase system, are there ever shorting blocks that would have the common permanently shorted to the bridge such that only 1 temporary shorting screw per phase would need to be installed to bypass CT's?
That's what I recall seeing: one grounding screw per phase. Have also seen little knife switches on 240V CT's.
What I mean is the screws for the grounded legs are left in place. Only the hot leg screw was removed. At least that's what I remember...
The little knife switches you are speaking about are probably shorting test switches. THose are different. Usually 2 poles per CT because each pole has a different purpose. Here's a shortng block I see frequently. Marathon 1604SC. Do they make one with a permenant connection for the current neutral conductor to the bridge so that to short a particular phase, you'd only have to install one screw per phase?1694563072684.png
I remember seeing little brass bars right on the CTs that rotate on a single screw in the middle.
