stevebea
- Southeastern PA
Most of the CT Shorting Blocks I see installed have wire jumpers. What do you guy's do? (a) Install wire jumpers (b) use the shorting screws (c) use the screws and install wire jumpers.
If method 'B' is not available, I go to 'A'.
Shorting screws are the easiest method. What are you doing that requires you to short the CT secondary. I work with many CT's, and have never had to work with a hot CT. I can see it being neccesary on a very rare occasion, just not often.
What are some service calls you guys have shorted out a CT's secondary using the screws or jumpers?
