JJWalecka
- New England
is CO/ALR the same thing as AL/CU? please explain the difference
I read that [SIZE=-1]If your home has aluminum wiring and you need to replace a switch or wall receptacle, [/SIZE][SIZE=-1]the replacement unit should bear the marking "CO/ALR". This means [/SIZE][SIZE=-1]"Copper Aluminum Revised" to differentiate these units from earlier models which were marked AL/CU. [/SIZE]
