Have a ground lug which indicates CU/AL. If I want to combine a copper an aluminum ground wire under the same screw, does the CU/AL reference meet the requirements of 110.14 for a "device intended for the purpose and conditions of use"?. An anti-oxidant (Noalox) will be used on the AL wire. This came up as an issue during a recent inspection where the AHJ insisted on a separate lug for each type of wire.
