Re: current 150+a. on grounding conductor
Don,
Thank you!
Duh on me!
I guess I had never thought about the impedance limiting the current to a maximum value, but of course that does make perfect sense.
The plant that I work at was wired when they allowed 277 volt loads to be on the high impedance grounding system. Well over half of our ground faults are found in HPS high bay lights. This facility makes OSB (orientated strand board). The process involves miles of hot oil lines running throughout the facility for pressing and drying, as well as hot air ducts used in the drying process for the aspen wafers.
Loss of power to a critical pump or fan would cause an overheating condition, which in turn would most definitely cause oil line rupture or dry wafer storage fire. The hot oil is at a temperature where it would instantly combust when exposed to ambient air. Good thing for backup generators and high impedance grounding systems. Matt
[ November 25, 2003, 12:36 PM: Message edited by: itasca_mn ]
