While inspecting a top floor unit in a 24 unit condo, I discovered the water heated baseboard pipes are slightly energized. Although the currently was relatively low, the length of the pipe gives off a very strong EMF reading throughout the unit (as much as 10mG 6 feet away from pipe with unit breakers off). The buyer insist on solving this problem during attorney review.
The 24 units in the building share same heater in the basement. Each unit has a zone valve controlled by thermostat. All baseboard pipes are laid out in a single loop of copper pipes. I also detected a current running on the water main in the basement. And there is no ground attached to water main.
There are several solutions I'm considering given a short amount of time I need to solve this problem
1. Find the source of the ground current by de-energize the entire unit. First make sure the source isn't from outside. And narrow down the source. A lot of hassle and I'm not sure if the building is willing to do this for a potential buyer.
2. Break the current going inside the heater pipe by installing a dielectric union. I'm not sure if this would break the eletric code, but technically both side of the dielectric union are still bond to the main pipes. Is there anyone with plumbing experience can tell me if a dielectric union can be used on a copper heated water pipe.
3. Another possibility is the controlled zone valves throughout the unit (which runs on 26v ac) is responsible for creating the current with induction.
Thanks in advance!
Thanks in advance!
