I have a building with a 1200a 480v 3p 4w. The 480 supplies power to 3 transformers for 208/120 building loads on 3 seperate breakers. It also supplies 480 3p power to a chiller panel with four commpressors on its own breaker and a pump panel with four pumps on its own breaker. All the moters are 3 phase, and the voltage is a little high a-b=498, a-c=496, b-c=488 and a-gr.=287, b-gr.=279, c-gr.=280. The problem is all moters draw more amps on a-b phase. comp. 1 69a,64a,61a. Comp.2 73a,62a,59a.The comp. tags are 81a. Pump 1 3.67a, 3.25a, 3.17a.and so on. There are 3 transformers on pole near building. One is phisicly larger but i don't know act. size. thanks, john
