I'm in Washington State and am installing 200 feet of track in a retail space. Our standard lighting calculation for track is 50 watts per foot, which would require 6 circuits at 120 volts. I'll be installing eighty 15 watt ceramic metal halide fixtures at 20 watts connected each, for a total of load of 1600 watts. At under 14 amps I could feed all of the track in the space with one 20 amp circuit at 120 volts.
Energy codes permit the current limiter rating to be substituted for the linear footage formula. I can install one on each track or install a remote panel between the track and the source panel but since I'm dealing with just one circuit I wondered if there would be a simpler and less expensive solution. I checked the web and came up empty. Then I wondered if the single breaker in the panel could be considered a current limiter with respect to the track? If so that would solve my problem. I couldn't come up with a down side as it seemed to address any concerns about exceeding the
I'll check with the AHJ tomorrow but thought I'd get a little feedback in the mean time.
Thanks
Thanks
