Grouch
- New York, NY
I never looked at the curve for a current limiting circuit breaker.
I attached the graph for one (current limiting breaker.pdf). My question is, is the diagonal line all the way on the left, labeled 'Maximum available peak current at 15% Power Factor'... is this line the same as the A-B line that you see on the graph for a current limiting fuse (see attached jpg file)?
