msteffin
- Sylvania, Ohio
My understanding of a current-limiting device is that it will lower the amount of current that a load side piece of equipment will see. I also remember reading in the NEC that current-limiting devices are not to be taken into consideration when determining the available fault current at the equipment (Control Panel). I have 2 questions.
1. Is there a way, per NEC, to utilize the current-limiting characteristics of a fuse to reduce the available fault current at the equipment? (other then having it series rated and tested under UL 508A)
2. Where in the NEC does it say that current-limiting devices can't be used in the calculations when calculating the available fault current?
