HotConductor
- Philadelphia
Last week I was called in to help another ec troubleshoot an intermittent main breaker tripping issue. He already had the store on a portable genny with three hot cables, one neutral and one ground(120/208/3 ph). There was an mdp with an 800 amp main and eleven breakers feeding panel boards and rooftop equipment. I found between 5-10 amps of current on each egc from the panel boards back to the mdp.
After the store was put back on utility power, the ground currents went back close to 0. Does this have something to do with the genny frame being bonded to the neutral?
