handimatt
- amarillo texas
I have a house with a 600 amp service panel and 4 subpanels. I have taken readings on the equipment grounding conductor and they read between 0.2 amps and 0.8 amps. We physically checked that there were no neutrals tied to equipment grounds. We found 5 issues and corrected. This did not affect the reading. One thing I noticed is that the grounds from all the panels were tied together, not just at the main grounding bus but through the #12 equipment ground junction points where 2 circuits from different panels occupy the same box. Secondly, I noticed that as the any load was increased or reduced on the whole system, the amperage on the ground increased and decreased proportionally. Thirdly, one of the sub-panels feeds a pool with a rebar shell as its equipotential bonding plane. Any thoughts on why the equipment ground shows amperage? Is this normal? I would think it should be zero but I am starting to wonder.
