We see current of .5 to 23 amps on our grounding systems at many different locations. Does the NEC or any other NFPA code or UL address this issue. What is acceptable? On the 23 amp system, we had the utilities company shut it down so that we could look for the sources. However, we still had 2 amps of current from stray voltages from Public Service. Some of this may be due to harmonics. Although, we have found neutrals that are bleeding into the grounded conductors. We did pay for a two point ground resistance test. All grounds from cold water, ground rod, building steel, and incased in concrete, all have less than 1 measured ohms.
