Depends on which line you reference your L-L voltage. If the reference is the lagging line?such as Vab, Vbc, Vca?then a 90? L-L current lag is a 60? L-N current lag, or a 90? L-L current lead is a 120? L-N current lead.... Now here's the question: is the L-L current leading or lagging the L-N voltage, since that would make the difference between 90+30=120 or 90-30=60deg?
Reference your voltage the other way?Vac, Vba, Vcb?and 90? L-L lag is 120? L-N lag, while a 90? L-L current lead would be 60? L-N current lead.
You have to take this into consideration where L-L current leads and lags combine through a common line, as the two voltages are referenced to their respective uncommon lines.
