Searchman2
New member
- Southern Ca
I have a system that consists of 2- 400 amps services. The Wh readings are read by a single meter. There are two CT's with a primary coil showing 200&200 secondary :5 amps. The POCO has a multiplier of 40 on the demand meter. I am questioning if the 40 multiplier is correct?
L1 and L2 phases enter the Ct's from opposing directions. From the research I have already done the one cancels out the other and the multiplier should be 20 not 40. Am I calculating the multiplier correctly?
