Therealcrt
- Kansas City
- Electrician
I’ve helped install CT cabinets before but always just landed the primary side and the secondary side under all the lugs, then mounted the window CT around the buss’s but that was it. I didn’t do anything with the meter enclosure so what else is there after that? Do I have to run wires from those CT’s to the meter enclosure it’s a 3 phase 480v 600amp. There are usually little screws or terminals on the CT’s if I remember but after looking at finish installs on some online I see wires coming off those.
