First let me give you a little background. I had a talk with the inspector before I began work on this pool since it was in a different jurisdiction from my usual work. I like to check with local officials to see if their codes are different. Anyway, he told me that the equipotential bonding jumper had to be bonded back to the main service ground rod. I questioned this saying that I normally don't ground the bonding jumper but he said that's what he wanted so that's what he got.
A couple days later the customer calls be back and says she's getting a tingle when she's in the pool and touches the concrete deck. The only thing I can think of is that it's from the bonding jumper being connected to ground so I'm going to disconnect it from the ground rod. Hopefully this solves the problem. Does anybody have any ideas of what could be causing this?
