as noted in Post 2.. you can sometimes run into zoning or other local obstacles, but putting that aside, are the two "houses" connected or are they separate structures ? If separate, have you/he discussed POCO adding a drop to the second house ?
Instead of going through that you can just put a submeter on the feeded to the tenant house and the landlord can read the usage themselve. Just to give you another option.
Yeah, I guess he doesn't want to drive over there every month to read the kwh used.
May check your local or state laws. Illegal for anyone to charge for power in NE but the POCO.
same in california
also in CA there are rules about having more than one service at a res property usually 1. If the home falls under this it could be called a bonafied inlaw house and get the second meter.
when a change in occupation occures it is supposed to revert back , but I doubt anyone would find out.
I agree, here the POCO would require a seperate address for the second meter and the addresses are assigned by our department and we may not let you do that without a legal lot split.
