I thought we were supposed to watch the pennies instead of the dollars.Never look at the dollars. Look at the usage.
Get a copy of the two bills. Look at the read dates and the meter readings. Using a daily average, read the meter today and see if the usage is still running high.
If it is still running high, take some load readings to verify the meter. The Kh value on the front of the meter gives you the secondary watt-hours per revolution constant. You will need to multiply the Kh by the CT ratio and PT ratio to get the primary Kh constant to get the actual watt-hours per revolution.
If the usage is still found to be high and the meter is reading correctly, start looking for some excessive current loads or loads that are not cycling off like they should.
Add: Loads that are not cycling off like a pump, heater, fans or other motors, etc.
was this bill read or estimated? when was the last read bill?
They test the big loads on a regular basis (I recommend annually). Medium sized loads are tested less often (I recommend every 2-4 years).Part of what you said, shouldn't that be POCO's job to make sure there meter is working correctly? Just wondering. Thank you.
I just cut off one of my water meters to avoid some freeze issues and found the cover broken and the hole full of dirt and roots.Also have had one at a small industrial plant where there meter quit spinning and it took the PoCo three months to get out there to fix it (They didn't notify the owner about this either). They estimated the bills for the three months and adjusted the bill when I got a call about the bill being way too high.
One of the gentlemen I work with at his home was getting estimated bills for several months and when they finally read the meter it was a lot less than the estimates so the utility assumed it rolled over and hit him with a few thousand dollar bill. It took threats of going to the public utlity commission to finally correct the situation.
As you may be aware, smart meters have nothing to do with it. If changing the meter made a difference, any new meter would yield the same result.Zappy, your profile reads you are in CA. Many of the utilities in CA are installing smart meters and many customers are reporting dramatic increases in there bills afterward. People are even going so far as to sue utilities to stop them from installing smart meters. Additionally, some utilities have raised there rates recently (PG&E, certainly has).
I think the best advise has already been given. Get some bills and start crunching numbers and talk to the POCO.
