billybobjojo
- seattle
I was recently told that when using cut in boxes in hospital rooms that you have to leave the ears on your devices like receptacles when they are installed to help with more metal to metal contact even with self grounding receptacles.
It has been the practice when installing cut in boxes to clip the ears off so one can ensure the receptacles are set back far enough to make the face plate flush with the wall. I was informed that instead one is use a slightly raised or beveled cover for this application. Is this a true?
