eeliasson
- Roundup, MT
So I've been getting a lot of call backs lately to houses that I've wired using Cutler Hammer CH series panels with afci/gfci breakers. Some houses, my own included, have not had any issues. Others however, are a constant pain in my butt! It's not just one circuit either, it's usually multiple issues. My solution has been to test, swap breakers, and if all else fails change to a standard breaker on important circuits like the fridge. The last house I wired has me pulling my hair out. The tripping is so random that it's hard to narrow it down. One example that I found is the master bedroom circuit. There are (4) led can lights in the bedroom and (1) semi-flush mount in the hall with edison bulbs, both on the same circuit. It seems that when both lights are on for a certain amount of time it will trip the breaker on a series fault code. Either light will run by itself with no problem. In the same house I also have a problem with the living room circuit and the foyer circuit interacting with each other. Both rooms have the same LED can lights. If both rooms have the lights on and you turn the tv/entertainment system on in the living room, after about 30 seconds the living room circuit trips on series fault. If I turn the foyer breaker off though, the living room circuit will not trip. There are several switch boxes that have both circuits but they are correctly separated except for the ground wires. I could go on and on but these are just a few examples. Thinking about switching to Homeline for future projects to see if I have the same problems. Any info or advice?
