A cutout box is typically like a safety switch/disconnect whereas a cabinet is an enclosure typically used to house a panelboard.
Here is what the NEC definitions are:
Cabinet. An enclosure that is designed for either surface mounting or flush mounting and is provided with a frame, mat, or trim in which a swinging door or doors are or can be hung.
Cutout Box. An enclosure designed for surface mounting that has swinging doors or covers secured directly to and telescoping with the walls of the box proper.
