No... Holes are enclosure based - this enclosure gets this pattern by this manufacturer, and different ones from the other one... NO HOLES - In bolt-on maybe? Special order in most cases... But definately not in the average BR type stab in load center...
I'm sure a number of us have seen them stupid LV panels with the bottom that has a 1G cut-in KO. I'm not sure which company - but one of them makes a plate with that in it that can be moved top to bottom with just 4 - 10/32's - like an insert. Thats what I'm thinking of... You want KO - just install it as is. You don't want KO's or the provided ones won't work for you - cut your on on the provided plate and drop it into place after removing what will be known as the hack plate......
