Is there any code or reason why you should not cut long barallel lugs if they are too long and providing a space or clearance issue.
For instance if I had a (2) hole long barallel lug and I cut it to only use one of the holes, would this be a violation of any code?
Other than voiding the UL listing of the lug I would also say you have taken away the needed contact area of the lug for carrying the load.
If I need to bend the lug to 45 degrees for better fit to a bus bar, can I bend a staight connector or do I have to buy a 45 deg.
I have never purchased a compression lug based on current rating, always cable size, and for the same cable size the lugs come in 1 or 2 hole versions.
