MTFBWY
- Central California
- Data Center Technician
Hello all, I’ve been lurking for a while and first time posting. I mounted a tv antenna and mast on the fascia board near top of the house. I plan to ground the mast and coax using 10AWG copper. I have (2) questions which I am 50/50 on (due to inexperience)
Question 1) can I use split bolt and attach the 10 awg ground wire from mast and coax ground bar to the (I think it is the ) GEC that comes from the breaker panel (see photos)) . From inside the garage I cut open the wall to see that it is clamped into a rebar sticking up (see photos). I assume that rebar is connected to the ground rod.
Second question : in the photo with the surge coax protector and grounding bar, I’d the orientation of the surge protector , and direction of coax correct?
I guess I have a 3rd question , that is, is the surge protector also called a discharge unit? Thanks
How do I add photos?
