jmsbrush
- Central Florida
Hello Everybody, I'm bidding A CVS Pharmacy. Is there anyone who has done this Type of job IN Florida? IF so how much was the Bid for? Thank you for the Help.
jmsbrush said:Hello Everybody, I'm bidding A CVS Pharmacy. Is there anyone who has done this Type of job IN Florida?
I couldnt agree more when I worked for a previous employer I wired three White Castles. And like Iwire said the first one was a real kick in the A$$ and my boss said that we kind of took it on the chin but when it came to the second and third one I was able to learn from past mistakes and was able to better prepare myself in some of the constuction phases like not needlessly running as many pipes on the ground rough and making better use of others. Because many of these prints are drawn up by engineers that have never spent a day in the field and so you learn what is redundant or unnessacary because you saw another similar project all the way thorough. Anyway good luck.iwire said:I have been involved with them up here and while I have no idea what the number was I can tell you with certainty it was not enough.
Many details ..... pod electric room ..... lots of underground .... many details .... burning up time ... did I mention many little details.
IMO the only way to make money is to do a bunch of them and consider the first one a costly education.
I know, it looks like it's just a little store with a pharmacy, but it had a surprisingly high number of circuits.
jmsbrush said:Hello Everybody, I'm bidding A CVS Pharmacy. Is there anyone who has done this Type of job IN Florida? IF so how much was the Bid for? Thank you for the Help.
tonyou812 said:I couldnt agree more when I worked for a previous employer I wired three White Castles. And like Iwire said the first one was a real kick in the A$$ and my boss said that we kind of took it on the chin but when it came to the second and third one I was able to learn from past mistakes and was able to better prepare myself in some of the constuction phases like not needlessly running as many pipes on the ground rough and making better use of others. Because many of these prints are drawn up by engineers that have never spent a day in the field and so you learn what is redundant or unnessacary because you saw another similar project all the way thorough. Anyway good luck.
IMO, if it is on the print it is necessary to install it or get a pass on not doing so.tonyou812 said:I couldnt agree more when I worked for a previous employer I wired three White Castles. And like Iwire said the first one was a real kick in the A$$ and my boss said that we kind of took it on the chin but when it came to the second and third one I was able to learn from past mistakes and was able to better prepare myself in some of the constuction phases like not needlessly running as many pipes on the ground rough and making better use of others. Because many of these prints are drawn up by engineers that have never spent a day in the field and so you learn what is redundant or unnessacary because you saw another similar project all the way thorough. Anyway good luck.
mike johnson said:Send me your plans and i'll give you a competitive number.
petersonra said:IMO, if it is on the print it is necessary to install it or get a pass on not doing so.
480sparky said:It's no fun starting a job with ground work and having a semi pull up with 600 light fixtures that you are required to accept.....
iwire said:Been there a few times and don't forget if you do not inventory it all you have no chance of claiming you where shorted items later.
