hello, new to the forum. I recently installed solar on a new construction. I installed solar on my accessory building which is where my meter base is located. I installed and 11 kW system on a 200 amp service so they D rated service breaker to 175 and put a 60 amp for solar. My home has a 200 amp shut off on the exterior and a 200 amp load center in the home. Do I have to D-rate both of those to 175 or can I leave them.
Thank you
Toby
Thank you
Toby
