don_resqcapt19 said:Chris,
You need to look at the next section, 410.32 where this is specifically permitted even where the fixture is not listed as a raceway.
Kal-EL said:Is it a code violation to daisy chain fluorescent fixtures with MC Cable? If so a code reference please.
It was put to me that a fluorescent fixture does not have a box fill capacity therefore you can not daisy chain the MC.
I had breakfast with another ME Sunday. We brought our code and Soars books right in the retaurant with us and spent 3 hours convincing ourselves about how little of it we realy knew!!don_resqcapt19 said:This is just another example of where the NFPA's move to "positive" language in an attempt to make the code easier to understand actually makes it harder. In the old codes the information in 410.32 was in the form of an exception to 410.31 making it very clear that there may be other options. With the current rule, there is no logical reason to read 410.32 after you have found your answer in 410.31.
nyerinfl said:I do this ALL the time. Even if I buy fixtures pre-whipped (which I do sometimes so the bulbs are already in there), I rip the whips out, and daisy chain MC. IMO, using whips and 1900 boxes everywhere is more work. Never once have I had an issue with an inspector over this. I do typically try to keep only 2 cables per fixture.
