jetlag
- Eatonton, Georgia
I need to install a bath ceiling light but I wont be able to get it out of the 3 ft from the Edge rule for both the Tub and shower both because they are only 5 ft apart , The code says I must use a damp location fixture , can some on describe how you recognize the difference in a damp location surface mounted fixture . I have also seen it posted that a wall mounted fixture inside the area does not have to be rated for damp location if not subject to shower spay , is that true?
