As per the 2011 NEC are there special wiring methods required for Damp location,
314.15 talks about wet location wiring methods need to be rated for wet locations
and 110.28 I do not see where it talks about damp locations.
Thank You.
And then sections 404 & 406 tell you what type of boxes switches and receptacles need to be installed in. Does a weather proof box need a compression connector to make it weatherproof? I need to look into that more.
