jrobie79
- Orlando, FL USA
Project Manager for a multifamily developer, we're having issues with our electrical inspector regarding an HVAC fan coil unit installed in the interstitial space above our tub/showers. It is completely sealed by taped drywall with duct mastic and fire caulking around all penetrations and has an access door below, roughly sized 48" L x 30" W.
See the attached section view of the pancake unit installation and how it is separated from the tub/shower:
Would this be considered a damp location (green bubbled area on photo)? It has no exposure to direct moisture, nor does it receive any shower spray. Our inspector is saying all the wiring of the unit needs to be rated for a damp location. The access panel is currently installed without a gasket, if it is indeed a damp location, would adding a rubber/neoprene/etc gasket to the panel eliminate the 'damp' classification?
